java-抽象类遇到的问题
作者:赖振军 | 时间:2017-7-4 15:02:51 | 阅读:7376| 只看该作者
package com.test.jun;
import com.test.jun.A.B;
abstract class A {
    public static final String FLAG = "CHINA";
    private String name = "june";
    public void setName(String name) {
this.name = name;
    public String getName() {
return name;
    public abstract void print();
  public static class B extends A{
   public void print() {
  // TODO Auto-generated method stub
  System.out.println("FLAG:" + FLAG);
  System.out.println("name:" +super.getName());
public class AbstractTest {
* @param args
public static void main(String[] args) {
//抽象类不能初始化,所以new A 是错误的
//A a=new A();
B b= new B();
b.print();
class B extends A{
//抽象类无法初始化的,需要初始化就别用抽象类,用抽象类的子类,当时new B时候还是报错。
错误为:No enclosing instance of type A is accessible. Must qualify the allocation with an enclosing instance of type A (e.g. x.new A() where x is an instance of A).
然后一直纳闷,不是说抽象类不能初始化,可以用抽象类的子类吗?然后百度一下。
答案是:我写的内部类是动态的,也就是开头以public class开头。而主程序是public static class main
解决方法为: class B extends A{   改为 public static class B extends A{
yzt2017 发表于:2017-10-17 10:13:09
谢谢楼主分享!楼主辛苦了!
[url=http://www.yunzhitu.com ]云智图[/ur
