常用的adb命令
作者:sean | 时间:2016-9-28 20:19:34 | 阅读:3990| 只看该作者
首先把adb配置到环境变量中
注意添加Java跟android环境变量;
ADB连接板子:
设置Root权限:shell@android:/#su
板子上的mac地址最好重新配下,如:shell@android:/#busybox ifconfig eth0 hw ether00:88:88:00:00:0a
开始adb:shell@android:/#startadbd
获取板卡IP地址:#busybox ifconfig
shell@android:/ #busybox ifconfig
eth0      Link encap:Ethernet  HWaddr 00:88:88:00:00:0A
          inetaddr:169.254.1.73 Bcast:169.254.255.255  Mask:255.255.0.0
          inet6 addr: fe80::288:88ff:fe00:1/64Scopeink
          UP BROADCAST RUNNING MULTICAST  MTU:1500 Metric:1
          RX packets:84 errors:0 dropped:0overruns:0 frame:0
          TX packets:3772 errors:0 dropped:0overruns:0 carrier:0
          collisi**:0 txqueuelen:30
          RX bytes:20217 (19.7 KiB)  TX bytes:1459734 (1.3 MiB)
          Interrupt:201 Base address:0x4000
lo        Link encapocal Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:16436 Metric:1
          RX packets:8029 errors:0 dropped:0overruns:0 frame:0
          TX packets:8029 errors:0 dropped:0overruns:0 carrier:0
          collisi**:0 txqueuelen:0
          RX bytes:681842 (665.8 KiB)  TX bytes:681842 (665.8 KiB)
shell@android:/ #
Step 4: 网线连接板子和电脑,在Dos下输入:
开启adb服务 adb start-server
C:\Documents andSettings\Administrator\android-sdks\platform-tools>adb disconnect
C:\Documents andSettings\Administrator\android-sdks\platform-tools>adb connect 169.254.1.73:5555
设置成功的话,就能在eclipse下run APK在板子上跑了。
(3)server的命令:
C:\Documents andSettings\Administrator\android-sdks\platform-tools>adb kill-server
C:\Documents andSettings\Administrator\android-sdks\platform-tools>adb start-server
(4)Install Apk:
安装第三方应用:
C:\Documents andSettings\Administrator\android-sdks\platform-tools>adb installE:\HelloWorld.apk
应用将被安装到data/app
安装系统应用:
C:\Documents andSettings\Administrator\android-sdks\platform-tools>adb shell
shell@android:/#mount -o remount rw system
shell@android:/#chmod 777 system/app
退出adb shell(CTRL+c),然后:
C:\Documents andSettings\Administrator\android-sdks\platform-tools>adb push E:\MLauncher.apksystem/app
(5)Uninstall Apk:
方法1:
C:\Documents andSettings\Administrator\android-sdks\platform-tools>adb uninstallpackage---->adb uninstall com.example.helloandroid(helloandroid.apk包名)
方法2:
卸载第三方应用
shell@android:/# su
shell@android:/ #rm-rf data/app/package-1.apk
卸载系统应用:
shell@android:/# su
shell@android:/#rm system/app/XXX.apk
(6)Android Debug Bridge version 1.0.29
-d                            - directs commandto the only connected USB device
                                 returns anerror if more than one USB device is present.
-e                            - directs commandto the only running emulator.
                                 returns anerror if more than one emulator is running.
-s <serial number>            - directs command to the USB deviceor emulator with
                                 the givenserial number. Overrides ANDROID_SERIAL
                                 environmentvariable.
-p <product name or path>     - simple product name like 'sooner', or
                                 arelative/absolute path to a product
                                 out directorylike 'out/target/product/sooner'.
                                 If -p is notspecified, the ANDROID_PRODUCT_OUT
                                 environmentvariable is used, which must
                                 be an absolutepath.
devices                       - list all connecteddevices
connect <host>[:<port>]       - connect to a device via TCP/IP
                                 Port 5555 isused by default if no port number is specified.
disconnect [<host>[:<port>]]  - disconnect from a TCP/IP device.
                                 Using thiscommand with no additional arguments
                                 willdisconnect from all connected TCP/IP devices.
device commands:
  adb push <local> <remote>    - copy file/dir to device
  adb pull <remote> [<local>]  - copy file/dir from device
  adb sync [ <directory> ]     - copy host->device only if changed
                                 (-l means listbut don't copy)
                                 (see 'adb helpall')
  adb shell                    - run remote shellinteractively
  adb shell <command>          - run remote shell command
  adb emu <command>            - run emulator c**ole command
  adb logcat [ <filter-spec> ] - Viewdevice log
  adb forward <local> <remote> -forward socket connecti**
                                 forward specsare one of:
                                  tcp:<port>
                                  localabstract:<unix domain socket name>
                                   localreserved:<unix domain socketname>
                                  localfilesystem:<unix domain socket name>
                                  dev:<character device name>
                                  jdwp:<process pid> (remote only)
  adb jdwp                     - list PIDs of processeshosting a JDWP transport
  adb install [-l] [-r] [-s] [--algo<algorithm name> --key <hex-encoded key> --iv <hex-encodediv>] <file>
                               - push thispackage file to the device and install it
                                 ('-l' meansforward-lock the app)
                                 ('-r' meansreinstall the app, keeping its data)
                                 ('-s' means install on SD cardinstead of internal storage)
                                 ('--algo','--key', and '--iv' mean the file is encrypted already)
  adb uninstall [-k] <package> - removethis app package from the device
                                 ('-k' means keep the dataand cache directories)
  adb bugreport                - return all information fromthe device
                                 that should beincluded in a bug report.
  adb backup [-f <file>] [-apk|-noapk] [-shared|-noshared][-all] [-system|-nosystem] [<packages...>]
                               - write anarchive of the device's data to <file>.
                                 If no -foption is supplied then the data is wr
itten
                                 to "backup.ab" in the currentdirectory.
                                 (-apk|-noapkenable/disable backup of the .apks themselves
                                    in thearchive; the default is noapk.)
                                 (-shared|-nosharedenable/disable backup of the device's
                                    sharedstorage / SD card contents; the default is noshared.)
                                 (-all means toback up all installed applicati**)
                                 (-system|-nosystem toggles whether -allautomatically includes
                                    systemapplicati**; the default is to include system apps)
                                (<packages...> is the list of applicati** to be backed up.  If
                                    the -all or-shared flags are passed, then the package
                                    list isoptional.  Applicati** explicitly givenon the
                                    commandline will be included even if -nosystem would
                                    ordinarilycause them to be omitted.)
  adb restore <file>           - restore device contents from the<file> backup archive
  adb help                     - show this help message
  adb version                  - show version num
scripting:
  adb wait-for-device          - block until device is online
  adb start-server             - ensure that there is a serverrunning
  adb kill-server              - kill the server if it isrunning
  adb get-state                - prints: offline | bootloader| device
  adb get-serialno             - prints: <serial-number>
  adb status-window            - continuously print device statusfor a specified device
  adb remount                  - remounts the /systempartition on the device read-write
  adb reboot [bootloader|recovery] - rebootsthe device, optionally into the bootloader or recovery program
  adb reboot-bootloader        - reboots the device into thebootloader
  adb root                     - restarts the adbd daemonwith root permissi**
  adb usb                      - restarts the adbddaemon listening on USB
  adb tcpip <port>             - restarts the adbd daemonlistening on TCP on the specified port
networking:
  adb ppp <tty> [parameters]   - Run PPP over USB.
Note: you should not automatically start a PPPconnection.
<tty> refers to the tty for PPP stream.Eg. dev:/dev/omap_csmi_tty1
[parameters] - Eg. defaultroute debug dumplocal notty usepeerdns
adb sync notes: adbsync [ <directory> ]
  <localdir> can be interpreted inseveral ways:
  - If <directory> is not specified, both/system and /data partiti** will be updated.
  - If it is "system" or"data", only the corresponding partition is updated.
environmentalvariables:
  ADB_TRACE                    - Print debug information.A comma separated list of the following values
                                 1 or all, adb,sockets, packets, rwx, usb, sync, sysdeps, transport, jdwp
  ANDROID_SERIAL               - The serial number to connectto. -s takes priority over this if given.
  ANDROID_LOG_TAGS             - When used with the logcatoption, only these debug tags are printed.
该会员没有填写今日想 ...
