车载碰撞和侧翻算法实现
作者:chenfangyu | 时间:2016-12-28 12:10:55 | 阅读:8969| 只看该作者
车载的侧翻算法根据上面的公式实现,而碰撞时根据三个方向的加速度的值。主要利用了传感器的**ensorChanged来实现。
[java] view plain copy
  • package com.leadcore.edr.packet;
  • import java.util.*;
  • import android.content.Context;
  • import android.hardware.Sensor;
  • import android.hardware.SensorEvent;
  • import android.hardware.SensorEventListener;
  • import android.hardware.SensorManager;
  • import java.lang.Math;
  • import android.util.Log;
  • public class GSensorService {
  •     private static final String TAG = "GSensorService";
  •     private Context mContext = null;
  •     private boolean mIsRolloverWarning = false;
  •     private boolean mIsCrashWarning = false;
  •     public GSensorService(Context context) {
  •         mContext = context;
  •     private final SensorEventListener mSensorListener = new SensorEventListener() {
  •         @Override
  •         public void **ensorChanged(SensorEvent event) {
  •             if (Sensor.TYPE_ACCELEROMETER == event.sensor.getType()) {
  •                 float xAxis = event.values[0];
  •                 float yAxis = event.values[1];
  •                 float zAxis = event.values[2];
  •                 float max_accelerometer = GlobalData.getCrashacceleration()
  •                                             * SensorManager.STANDARD_GRAVITY / 10;
  •                 boolean isOverAccelerometer = Math.abs(xAxis) > max_accelerometer
  •                                             || Math.abs(yAxis) > max_accelerometer
  •                                             || Math.abs(zAxis) > max_accelerometer;
  •                 if (isOverAccelerometer && !mIsCrashWarning) {
  •                     mIsCrashWarning = true;
  •                     GlobalData.setWarningFlag(JTT808.MSG_WARN_CRASH_WARN);
  •                     Log.i(TAG, "crash warning.");
  •                 } else if (!isOverAccelerometer && mIsCrashWarning) {
  •                     mIsCrashWarning = false;
  •                     GlobalData.ClearWarningFlag(JTT808.MSG_WARN_CRASH_WARN);
  •                 double rad2 = Math.atan(xAxis / Math.sqrt(yAxis * yAxis + zAxis * zAxis));
  •                 double degree2 = Math.toDegrees(rad2);
  •                 int max_degree = GlobalData.getCrashDegree();
  •                 if (Math.abs(degree2) >= max_degree && !mIsRolloverWarning) {
  •                     mIsRolloverWarning = true;
  •                     GlobalData.setWarningFlag(JTT808.MSG_WARN_ROLLOVER);
  •                     Log.i(TAG, "Roll over warning.");
  •                 } else if (Math.abs(degree2) < max_degree && mIsRolloverWarning) {
  •                     GlobalData.ClearWarningFlag(JTT808.MSG_WARN_ROLLOVER);
  •                     mIsRolloverWarning = false;
  •         @Override
  •         public void onAccuracyChanged(Sensor sensor, int accuracy) {
  •             // Not used.
  •     private void registerListener() {
  •         SensorManager sm = (SensorManager)mContext.getSystemService(Context.SENSOR_SERVICE);
  •         sm.registerListener(mSensorListener, sm.getDefaultSensor(Sensor.TYPE_ACCELEROMETER),
  •                         SensorManager.SENSOR_DELAY_NORMAL);
  •     public void start()  {
  •         registerListener();
点赞2
liugewill 发表于:2017-3-24 11:41:46
