MSC8X28 command list
作者:charles | 时间:2016-11-29 19:11:17 | 阅读:3539| 只看该作者
UART>
UART>ls
rr      - read register
wr      - write  register
mm      - memory monitor test
rrb     - read register
wrb     - write  register
rep     - Repeat uart command
ls      - Show command list.
help    - Show command Help.
md      - Memory Dump.
mf      - Memory Fill.
rrs     - read sensor register
rr2s    - read sensor2 register
wrs     - write  sensor register
wrs2    - write  sensor2 register
rrl     - read LCD register
wrl     - write LCD register
rrd     - dump 256 registers
ispinfo - get ISP Info
sonix   - get Sonix Info
spirf   - send a jpg file via spi
mode    - AHC_SetMode
mount   - AHC_MountStorageMedia
esd     - ESD Simulation
ver     - print version
format  - format media
chkstk  - Check task stack
tt      - Print all task
rt      - Print ready Task
ct      - Print current task
key     - Send Key event
lcdinit -
gpio    - read write gpio
tp0     - playback sound effect
tp1     - playback sound effect
tp2     - playback sound effect
test2   - playback sound effect
snd     - playback sound effect
movz    - move zoom motor
movf    - move focus motor
mt      -
motor_reg_read  - motor reg read
motor_reg_write - motor reg write
power_off       - power off device
dump_dcf        - Dump dcf database
vif_delay_cell  - Set VIF delay cell, the dDelayCell value is 0 ~ 3
rk      - UartCmdSensorPsenCtrl
sr      - UartCmdReadSensorI2c
sw      - UartCmdWriteSensorI2c
hdat    - UartCmdReadZFOUT
pi      - Enable PI
osdst   - UartOSDSetSemiTransparent
osdte   - UartOSDSetTransparentEnable
osdal   - UartOSDSetAlphaBlendingEnable
osdrot  - UartOSDSetRotate
osdmirr - UartOSDSetMirror
osdinit - UartOSDInit
osduninit       - UartOSDUninit
osdcbuf - UartOSDCreateBuffer
osd**  - UartOSDGetCurrentDisplay
osdscd  - UartOSDSetCurrentDisplay
osdgatt - UartOSDGetDisplayAttr
osdrf   - UartOSDRefresh
osda    - UartOSDSetSetActive
osdcls  - UartOSDSetClearBuffer
osddelbuf       - UartOSDDestroyBuffer
osdsc   - UartOSDSetColor
osdp    - UartOSDDrawPixel
osdrect - UartOSDDrawRect
osdfillroundrect        - UartOSDDrawRoundedRect
osdfrect        - UartOSDDrawFillRect
osdirect        - UartOSDDrawInvertRect
osdtext - UartOSDDrawText
osdjpeg - UartOSDDrawJpeg
sdfmt   - UartFormatSD
ocg     - OsCounterGet
oci     - OsCounterInit
tmi     - OsCounterInit
tm      - OsCounterInit
tmd     - OsCounterInit
dump_adas       - Dump ADAS Init params
chg     - UartCmdChargerOperation 0xFF-detect
0-100mA
1-500mA
2-1.5A
3-Suspend
aelogstart      -  Start AE log to file
aelogend        -  Save AE log to file
aflog   -  Save AF log to file
acclog  -  Save ACC log to file
aewnd   -  Get AE window size
setscn  -  set scene mode
getscn  -  get scene mode
setie   -  set image effect mode
getie   -  get image effect mode
setsatlv        -  set saturation level (-100~100)
ae      -  AE Enable/Disable
af      -  AF Enable/Disable
awb     -  AWB Enable/Disable
fd      -  Face Detection Enable/Disable
getfd   -  Get Face Detection Result
afzt    -  enable/disable af zoom track mode
getaeacc        -  Get AE ACC by window
getawbacc       -  Get AWB ACC by window
getacc  -  Get AEAWB ACC by window
afacc   -  Get AF ACC by window
getaewndsz      -  Get AE wnd size
preview -  DSC preview Enable/Disable
previewmode     -  Preview mode: 1080p/720p
setjpgq -  Set JPEG Quality
res     -  get preview resolution
setres  -  set preview resolution
scres   -  get still capture resolution
setscres        -  set still capture resolution
setaemode       -  Switch AE mode(0:Auto 1:ISO_PRIORITY)
getaemode       -  Get AE mode(0:Auto 1:ISO_PRIORITY)
setaelockmode   -  Switch AE Lock mode
getaelockmode   -  Get AE Lock mode
setaeisomode    -  Switch AE ISO mode
getaeisomode    -  Get AE ISO mode
setaeevbiasmode -  Switch AE ev bias mode
getaeevbiasmode -  Get AE ev bias mode
setaemetermode  -  Switch AE Metering mode
getaemetermode  -  Get AE Metering mode
setis   -  Switch Still Image Stablizer mode
getis   -  Get Still Image Stablizer mode
getflk  -  Get AE Flicker mode
setflk  -  Set AE Flicker mode
gettrow -  Get Sensor T row
getaespd        -  Get AE speed mode
setaespd        -  Set AE speed mode
getaeslowshutter        -  Get AE Slow shutter mode
setaeslowshutter        -  Set AE Slow shutter mode
setaemaxagain   - Set AE Max Again time(ex.1,2,3...)
getaemaxagain   - Set AE Max Again time(ex.1,2,3...)
setaemaxdgain   - Set AE Max Dgain time(ex.1,2,3...)
getaemaxdgain   - Set AE Max Dgain time(ex.1,2,3...)
setaemaxtotalgain       - Set AE Max Totalgain time(ex.1,2,3...,40)
getaemaxtotalgain       - Set AE Max Totalgain time(ex.1,2,3...,40)
setaetv -  Set AE Tv
setaesv -  Set AE Sv
getaetv -  Get AE Tv
getaesv -  Get AE Sv
getshuttermode  -  Get AE shutter mode
setshuttermode  -  Set AE shutter mode
setaemanualagain        -  set manual sensor AGain
setaemanualdgain        -  set manual sensor DGain
getaemanualexptime      -  Get AE shutter mode
setaemanualexptime      -  Set AE shutter mode
getaeggain      -  Get AE gamma gain parameters
setaeggain      -  Set AE gamma gain parameters
getaemaxsvtype  -  Get AE max sv type
setaemaxsvtype  -  Set AE max sv type
setawbmode      -  Switch AWB mode
getawbmode      -  Get AWB mode
setwb1pt        -  Set WB One Puse Trigger
afpos   -  move af motor to target pos
cfp     -  Current focus position
zoompos -  move zoom motor to target pos
czp     -  Current zoom position
stillaf -  still af operation
getafinfpos     -  get af inf position
setafinfpos     -  set af inf position
getafcurr2infpos        -  get af curr to inf position
setafcurr2infpos        -  set af curr inf position
getafstyle      -  get af style
setafstyle      -  set af style
getafmovietype  -  get af movie type
setafmovietype  -  set af movie type
getafmanrge     -  get af manual range mode
setafmanrge     -  set af manual range mode
afmanpos        -  set af manual position
getafmovparm    -  get af movie parameters
setafmovparm    -  set af movie parameters
setafactspt     -  set af active spot
getiqparm       -  get IQ tuning parameters
setiqparm       -  set IQ tuning parameters
setviflch       -  set VIF Latch Byte
setsnrreg       -  set Sensor I2C Register
setcolorid      -  set color ID
ispdgain        -  set isp digital gain
setexptime      -  set exposure time
getexptime      -  get exposure time
setaeagain      -  set sensor AGain
setaedgain      -  set sensor DGain
mtinit  -  motor init
zofd    -  motor forward
zobd    -  motor backward
zostop  -  motor Stop
zohome  -  motor Home
zotest  -  motor test
fotest  -  motor test
foset   -  motor test
fohome  -  motor Home
fostop  -  motor Home
foext   -  ExciteCtrl
fostat  -  ExciteCtrl
switch  -  switch media
nandspa -  nand operation r/w, reg
ps      -  play sound effect in NAND
lds     -  load sound effect into Dram
sv      -  Set volume in DB
initISPvalue    -  Write default value to disk
wISPvalue       -  Write default value from disk
rISPvalue       -  Read default value to disk
wMenuvalue      -  Write Menu settings value to disk
rMenuvalue      -  Read Menu settings value from disk
wSharpnessC     -  Write sharpness center
wSharpness      -  Write sharpness Level
wGammaC -  Write gamma center
wGamma  -  Write gamma Level
wContrastC      -  Write contrast center
wContrast       -  Write contrast Level
wSaturateC      -  Write Saturate center
wSaturate       -  Write Saturate Level
createFact      -  Create Factory Menu settings to disk
rn      -  Read NAND value
wn      -  Writh NAND value
lcdcolmtx       -  Set LCD color matrix
lcdbri  -  Set LCD brightness, 0~255 default 64
lcdcont -  Set LCD contrast, 0~255 default 64
lcdbri_r        -  Set LCD Red brightness, 0~127 default 64
lcdcont_r       -  Set LCD Red contrast, 0~127 default 64
lcdbri_b        -  Set LCD Blue brightness, 0~127 default 64
lcdcont_b       -  Set LCD Blue contrast, 0~127 default 64
lcdinv  -  Invert LCD
lcdwr   -  Write LCD register
lcddotclk       -  Get RGB dot clock
setrtc  -  SetRTCValue
getrtc  -  GetRTCValue
2003lenst       -  Get The ADC value of lens temperature
2003poweroff    -  Disable DCDC and LDO to powerdown system
sleepmode       -  Enable/Disable slppemode
wrPMU   -  Write reg of PMU
rrPMU   -  red reg from PMU
getawbgainwhiteblock    -  get awb R G B gain
afgetresult     -  get af result
stillafpos      -  get stillaf pos
lscsraw -  LS and CS calibration
ispmod  - ISP Module switch
sdctest - SDC test
wdr     - WDR
afinfposcali    -  af infinity position calibration
lscscali        -  Save Raw after LS and CS shading
aeawbcali       -  AE and AWB1 Calibration
awb0cali        -  AWB0 Calibration
awbcaldata      -  AWB Calculate data
getawbxy        -  Get AWB XY value
getawbrgb       -  Get AWB RGB value
getid   -  Get ISP condtion id and Again,Dgain,Exptime
aecali  -  Save Raw after LS and CS shading and calibration data for AE Calibration
aemingainchk    -  Check AE minimum gain check
setlscsfromsd   -  Set LS CS table from AitOutBin.bin from SD card
getraw  -  Get Raw after off shading
getraw2 -  Get raw data
getcsraw        -  Get Raw after Luma/Chroma shading
setcontrast     -  Set contrast
getcontrast     -  Get contrast
setsharpness    -  Set sharpness
getsharpness    -  Get sharpness
getjpg  -  Get capture jpeg
setcancelflick  -  Set cancel flicker mode
getcancelflick  -  Get cancel flicker mode
setdbbrk        -  Set dbg break
getdbbrk        -  Get dbg break
clrlog  -  Clr dbg log
dumplog -  Dump dbg log
setdefcmdl      -  Set UserDef CmdL
dpmenu  -  Dump Menu Setting
dpsnrtype       -  Dump sensor type
Burnin  -  motor test
checkispbin     -  Check calibration bin data
genispbin       -  Read calibration bin data and generate isp bin
rdcalibin       -  Read calibration bin data and write it to flash
rstcalibin      -  Reset calibration flash data to uncalibrated
dbg_l   - set dbg level
fm      - Show function menu
usbmode - Set usb mode
rgb     -  RGB signal control
hdmi    -  HDMI output
tv      -  TV
t       -  Test
sdm     -  SetDisplayMode
rf      -  DisplayRefresh
bl      -  Backlight
errormsg        -  Error message
lensmsg -  Lens Error message
vrp     -  Video Record Pause
vrr     -  Video Record Resume
ui      -  UI test
swp     -  SetWinPriority
canh    -  HDMI Get Event Enable
sendh   -  HDMI Send Event Enable
sendm   -  Send AHL Message Enable
strobeinit      -  UartCmd_StrobeInit
strobecharge    -  UartCmd_StrobeCharge
strobeready     -  UartCmd_StrobeReady
strobetriggerinit       -  UartCmd_StrobeTriggerInit
strobetrigger   -  UartCmd_StrobeTrigger
setgain - Video record Gain
getgain - Video record Gain
battery - Enable/Disable print battery level
speaker - Enable/Disable speaker
m       - set evtarget offset
uis     -  Show Current UI State
repeatplay      - repeat Play current video file
GPSOP   - GPS related Operation
NMEA    - GPS NMEA Info.
GsensorTest     - G-Sensor test Operation
vmd     - Motion Detection Parm
lb      - Low Battery Test
cpa     -  Copy All
ldws    -  LDWS switch
tvtest  - Test TV Colorbar, Param-1: 0:Off, 1:On; Param-2: 0:NTSC, 1AL; Param-3: 0:8-bar, 1:8-bar+3 gray + 2 strip
rtvbright       - Get TV Brightness
wtvbright       - Set TV Brightness, 0~255
rtvcontrast     - Get TV Contrast
wtvcontrast     - Set TV Contrast 0~511
rtvsaturation   - Get TV saturation
wtvsaturation   - Set TV Saturation 0~255
wtvgamma        - Set TV Gamma 0~4096
rtvgamma        - Get TV Gamma
ddosd   - Dynamic Download OSD
aff     - AIT Format Free
setmsdclock     -
laud    - Get Live ausio
pipswp  -  swap front/rear cam preview
dspyiq  -  Set panel IQ
mode    - AHC_SetMode
uimode  - UI_SetMode
ucm     - Test Uart command
UART>
