Android中Bitmap和Drawable
作者:LiuJy | 时间:2016-10-31 20:13:50 | 阅读:4422| 只看该作者
一、相关概念
1、Drawable就是一个可画的对象,其可能是一张位图(BitmapDrawable),也可能是一个图形(ShapeDrawable),还有可能是一个图层(LayerDrawable),我们根据画图的需求,创建相应的可画对象
2、Canvas画布,绘图的目的区域,用于绘图
3、Bitmap位图,用于图的处理
4、Matrix矩阵
二、Bitmap
1、从资源中获取Bitmap
    Resources res = getResources();
    Bitmap bmp = BitmapFactory.decodeResource(res, R.drawable.icon);
2、Bitmap → byte[]
    public byte[] Bitmap2Bytes(Bitmap bm) {
        ByteArrayOutputStream baos = new ByteArrayOutputStream();
        bm.compress(Bitmap.CompressFormat.PNG, 100, baos);
        return baos.toByteArray();
3、byte[] → Bitmap
    public Bitmap Bytes2Bimap(byte[] b) {
        if (b.length != 0) {
            return BitmapFactory.decodeByteArray(b, 0, b.length);
        } else {
            return null;
4、Bitmap缩放
    public static Bitmap zoomBitmap(Bitmap bitmap, int width, int height) {
        int w = bitmap.getWidth();
        int h = bitmap.getHeight();
        Matrix matrix = new Matrix();
        float scaleWidth = ((float) width / w);
        float scaleHeight = ((float) height / h);
        matrix.postScale(scaleWidth, scaleHeight);
        Bitmap newbmp = Bitmap.createBitmap(bitmap, 0, 0, w, h, matrix, true);
        return newbmp;
  5、将Drawable转化为Bitmap
    public static Bitmap drawableToBitmap(Drawable drawable) {
            // 取 drawable 的长宽
            int w = drawable.getIntrinsicWidth();
            int h = drawable.getIntrinsicHeight();
            // 取 drawable 的颜色格式
            Bitmap.Config config = drawable.getOpacity() != PixelFormat.OPAQUE ? Bitmap.Config.ARGB_8888
                    : Bitmap.Config.RGB_565;
            // 建立对应 bitmap
            Bitmap bitmap = Bitmap.createBitmap(w, h, config);
            // 建立对应 bitmap 的画布
            Canvas canvas = new Canvas(bitmap);
            drawable.setBounds(0, 0, w, h);
            // 把 drawable 内容画到画布中
            drawable.draw(canvas);
            return bitmap;
6、获得圆角图片
    public static Bitmap getRoundedCornerBitmap(Bitmap bitmap, float roundPx) {
        Bitmap output = Bitmap.createBitmap(w, h, Config.ARGB_8888);
        Canvas canvas = new Canvas(output);
        final int color = 0xff424242;
        final Paint paint = new Paint();
        final Rect rect = new Rect(0, 0, w, h);
        final RectF rectF = new RectF(rect);
        paint.setAntiAlias(true);
        canvas.drawARGB(0, 0, 0, 0);
        paint.setColor(color);
        canvas.drawRoundRect(rectF, roundPx, roundPx, paint);
        paint.setXfermode(new PorterDuffXfermode(Mode.SRC_IN));
        canvas.drawBitmap(bitmap, rect, rect, paint);
        return output;
7、获得带倒影的图片
    public static Bitmap createReflectionImageWithOrigin(Bitmap bitmap) {
        final int reflectionGap = 4;
        matrix.preScale(1, -1);
        Bitmap reflectionImage = Bitmap.createBitmap(bitmap, 0, h / 2, w,
                h / 2, matrix, false);
        Bitmap bitmapWithReflection = Bitmap.createBitmap(w, (h + h / 2),
                Config.ARGB_8888);
        Canvas canvas = new Canvas(bitmapWithReflection);
        canvas.drawBitmap(bitmap, 0, 0, null);
        Paint deafalutPaint = new Paint();
        canvas.drawRect(0, h, w, h + reflectionGap, deafalutPaint);
        canvas.drawBitmap(reflectionImage, 0, h + reflectionGap, null);
        LinearGradient shader = new LinearGradient(0, bitmap.getHeight(), 0,
                bitmapWithReflection.getHeight() + reflectionGap, 0x70ffffff,
                0x00ffffff, TileMode.CLAMP);
        paint.setShader(shader);
        // Set the Transfer mode to be porter duff and destination in
        paint.setXfermode(new PorterDuffXfermode(Mode.DST_IN));
        // Draw a rectangle using the paint with our linear gradient
        canvas.drawRect(0, h, w, bitmapWithReflection.getHeight()
                + reflectionGap, paint);
        return bitmapWithReflection;
三、Drawable
1、Bitmap转换成Drawable
    Bitmap bm=xxx; //xxx根据你的情况获取
    BitmapDrawable bd= new BitmapDrawable(getResource(), bm);
    因为BtimapDrawable是Drawable的子类,最终直接使用bd对象即可。
2、Drawable缩放
    public static Drawable zoomDrawable(Drawable drawable, int w, int h) {
        int width = drawable.getIntrinsicWidth();
        int height = drawable.getIntrinsicHeight();
        // drawable转换成bitmap
        Bitmap oldbmp = drawableToBitmap(drawable);
        // 创建操作图片用的Matrix对象
        // 计算缩放比例
        float sx = ((float) w / width);
        float sy = ((float) h / height);
        // 设置缩放比例
        matrix.postScale(sx, sy);
        // 建立新的bitmap,其内容是对原bitmap的缩放后的图
        Bitmap newbmp = Bitmap.createBitmap(oldbmp, 0, 0, width, height,
                matrix, true);
        return new BitmapDrawable(newbmp);
该会员没有填写今日想 ...
