Launcher系统默认设置修改总结
作者:果果 | 时间:2016-9-30 17:26:14 | 阅读:4100| 只看该作者
Launcher系统默认设置修改总结
1、launcher的布局太居中,要想两边拉伸
<\packages\apps\Launcher2\res\values\dimens.xml>
    <dimen name="  apps_customize_pageLayoutPaddingLeft">40dp</dimen>
    <dimen name="  apps_customize_pageLayoutPaddingRight">40dp</dimen>
apps tab栏的宽度( Launcher2 icon 数目、大小)
\packages\apps\Launcher2\res\layout-sw720dp\workspace.xml>
    launcher:cellCountX="10"
    launcher:cellCountY="6"
2、或者不想改数目:
<\packages\apps\Launcher2\src\com\android\launcher2\AppsCustomizeTabHost.java>
    protected void onMeasure(int widthMeasureSpec, int heightMeasureSpec) {
          mTabs.getLayoutParams().width = contentWidth   + 108;
3、workspace、AppsCustomize的cell大小:
<\packages\apps\Launcher2\res\values-sw600dp\dimens.xml>
    <dimen name="workspace_cell_width">110dip</dimen>
    <dimen name="workspace_cell_height">110dip</dimen>
    <dimen name="apps_customize_cell_width">110dp</dimen>
    <dimen name="apps_customize_cell_height">110dp</dimen>
4、里面icon的大小:
     <dimen name="app_icon_size">80dp</dimen>
5、workspace没有拖动,第二页第一个icon出现在第一页的最右边:
加大workspace的宽度,或间距:
workspace的paddingLeft、paddingRight:
<\packages\apps\Launcher2\res\values-sw600dp-land\dimens.xml>
    <dimen name="workspace_left_padding">50dip</dimen>
    <dimen name="workspace_right_padding">50dip</dimen>
workspace两屏间距:
<dimen name="workspace_page_spacing">100dp</dimen>
修改workspace的字体大小:
如果没有就添加:
<\packages\apps\Launcher2\res\values-sw480dp\styles.xml>
    <style name="WorkspaceIcon.Landscape">
        <item name="android:textSize">13sp</item>
    </style>
6、加wallpaper:
1.<\packages\apps\Launcher2\res\values-sw600dp\wallpapers.xml>
   加wallpaper的名字
2.<\packages\apps\Launcher2\res\drawable-nodpi>
   加如wallpaper
7、gallery的widget默认添加到workspace上:
<\packages\apps\Launcher2\res\xml\default_workspace.xml>
    <!-- Middle screen [2] -->
    <appwidget
        launcher:packageName="com.android.gallery3d"
        launcher:className="com.android.gallery3d.gadget.PhotoAppWidgetProvider"
        launcher:screen="2"
        launcher:x="1"
        launcher:y="0"
        launcher:spanX="3"
        launcher:spanY="3" />
<\packages\apps\Gallery2\src\com\android\gallery3d\gadget\PhotoAppWidgetProvider.java>
    @Override
    public void onUpdate(Context context,
            for (int id : appWidgetIds) {
                if(id == 2){
                    helper.setWidget(id,WidgetDatabaseHelper.TYPE_SHUFFLE, null);
8、在桌面上添加网页的快捷方式:
    <shortcut
        launcher:title="@string/application_name"
        launcher:icon="@drawable/ic_no_applicati**"
        launcher:uri="http://www.aaa.com"
        launcher:screen="0"
        launcher:x="0"
        launcher:y="3" />
9、在桌面上默认放文件夹:
     <folder
          launcher:screen="2"
          launcher:x="2"
          launcher:y="2"
          launcher:title = "@string/application_name" >
     <favorite
          launcher:className="com.android.deskclock.DeskClock"
          launcher:packageName="com.android.deskclock"
          launcher:container="1"
          launcher:x="0"
          launcher:y="0" />
     <favorite
          launcher:className="com.android.calculator2.Calculator"
          launcher:packageName="com.android.calculator2"
          launcher:x="0"
          launcher:y="0" />
     </folder>
10、桌面上添加快捷方式,点击播放视频:
<\packages\apps\Launcher2\res\xml-sw720dp\default_workspace.xml>
<shortcut launcher:title="@string/application_name"
launcher:icon="@drawable/ic_launcher_application"
launcher:uri="[url=]file:///mnt/sdcard/external_sdcard/1...playermenu;end[/url]"
launcher:screen="2"
   launcher:x="1"
launcher:y="1" />
11、安装apk,显示隐藏的google play:
1.写google显示的apk:
GooglePlayShow的activity:
        ComponentName componentname = new ComponentName("com.android.vending", "com.android.vending.AssetBrowserActivity");
        packagemanager.setComponentEnabledSetting(componentname, 1, 1);
        componentname = new ComponentName("com.example.googleplayshow", "com.example.googleplayshow.MainActivity");
        packagemanager.setComponentEnabledSetting(componentname, 2, 1);
2.<\packages\apps\Launcher2\src\com\android\launcher2\LauncherModel.java>
            } else if (Intent.ACTION_PACKAGE_ADDED.equals(action)) {
                if (!replacing) {
                         if(packageName.equals("com.example.googleplayshow")){
                              context.startActivity(new Intent().setComponent(new ComponentName("com.example.googleplayshow", "com.example.googleplayshow.MainActivity")).setFlags(Intent.FLAG_ACTIVITY_NEW_TASK));
                    op = PackageUpdatedTask.OP_ADD;
                } else {
                    op = PackageUpdatedTask.OP_UPDATE;
隐藏google search:
<\packages\apps\Launcher2\src\com\android\launcher2\Launcher.java>
    private void setupViews() {
        mSearchDropTargetBar = (SearchDropTargetBar) mDragLayer.findViewById(R.id.qsb_bar);
        mSearchDropTargetBar.hideSearchBar(false);
    void showWorkspace(boolean animated, Runnable onCompleteRunnable) {
        //mSearchDropTargetBar.showSearchBar(wasInSpringLoadedMode);
12、widget中隐藏google play:
<\packages\apps\Launcher2\src\com\android\launcher2\AppsCustomizePagedView.java>
updatePackages里面添加:
if(!widget.provider.getPackageName().equals("com.android.vending") && !widget.provider.getPackageName().equals("com.android.vending.MarketWidgetProvider")){
    mWidgets.add(widget);
13、clock的widget下部分显示不全,向上调
<\packages\amlogic\Launcher2\res\values\dimens.xml>
<dimen name="app_widget_preview_padding_top">10dp</dimen>
修改widget的text的size:
<\packages\amlogic\Launcher2\res\layout\apps_customize_widget.xml>
  <TextView xmlns:android="http://schemas.android.com/apk/res/android"
     android:id="@+id/widget_name"
     android:textSize="20sp" />
14、launcher中隐藏一个app:
需要该app的packageName,例如要隐藏settings:
        private void loadAllAppsByBatch() {
                    apps = packageManager.queryIntentActivities(mainIntent, 0);
                    ResolveInfo removeApp = null;
                    for(ResolveInfo info:apps){
                        if(info.activityInfo.packageName.equals("com.android.settings")){
                                removeApp = info;
                    if(removeApp != null){
                        apps.remove(removeApp);
15、launcher中隐藏多个app: 红色为改动部分
   final PackageManager packageManager = mContext.getPackageManager();
            List<ResolveInfo> apps = new ArrayList<ResolveInfo>();
            List<ResolveInfo> allApps = null;
            int N = Integer.MAX_VALUE;
            int startIndex;
            int i=0;
            int batchSize = -1;
            while (i < N && !mStopped) {
                if (i == 0) {
                    mAllAppsList.clear();
                    final long qiaTime = DEBUG_LOADERS ? SystemClock.uptimeMillis() : 0;
                    allApps = packageManager.queryIntentActivities(mainIntent, 0);
                    for(ResolveInfo info : allApps){
                        if(info.activityInfo != null
                                && !info.activityInfo.packageName.equalsIgnoreCase("com.android.email")
                                && !info.activityInfo.packageName.equalsIgnoreCase("com.android.providers.downloads.ui")
                                && !info.activityInfo.packageName.equalsIgnoreCase("com.adobe.flashplayer")){
                            apps.add(info);
