Android系统网络调试常用命令
作者:Alanz | 时间:2016-9-30 15:03:02 | 阅读:6916| 只看该作者
1. ifconfig 查看网络装填
2. Android wifi log 过滤logcat -s mingzi
3. netstat 查看协议,网络状态
查看:protocol     recv-q     send-q     local address       Foreign address     state
4. netcfg 查看网络配置类型
5. 启动(关闭)某个网络如:
netcfg eth0 up(down)or(busybox ifconfig eth0 up(down))
6. Ping 连接IP地址
7. Wpa_supplicant命令
Wpa_cli  进入wpa cilient 命令模式,help
> help
commands:
  status [verbose] = get current WPA/EAPOL/EAP status
  //ifname = get current interface name
  ping = pings wpa_supplicant
  //relog = re-open log-file (allow rolling logs)
  note <text> = add a note to wpa_supplicant debug log
  //mib = get MIB variables (dot1x, dot11)
  help [command] = show usage help
  interface [ifname] = show interfaces/select interface
  level <debug level> = change debug level
  license = show full wpa_cli license
  quit = exit wpa_cli
  set = set variables (shows list of variables when run without arguments)
  get <name> = get information
  logon = IEEE 802.1X EAPOL state machine logon
  logoff = IEEE 802.1X EAPOL state machine logoff
  pmksa = show PMKSA cache
  reassociate = force reassociation
  preauthenticate <BSSID> = force preauthentication
  identity <network id> <identity> = configure identity for an SSID
  password <network id> <password> = configure password for an SSID
  new_password <network id> <password> = change password for an SSID
  pin <network id> <pin> = configure pin for an SSID
  otp <network id> <password> = configure one-time-password for an SSID
  passphrase <network id> <passphrase> = configure private key passphrase
    for an SSID
  bssid <network id> <BSSID> = set preferred BSSID for an SSID
  blacklist <BSSID> = add a BSSID to the blacklist
  blacklist clear = clear the blacklist
  blacklist = display the blacklist
  log_level <level> [<times**p>] = update the log level/times**p
  log_level = display the current log level and log opti**
  list_networks = list configured networks
  select_network <network id> = select a network (disable others)
  enable_network <network id> = enable a network
  disable_network <network id> = disable a network
  add_network = add a network
  remove_network <network id> = remove a network
  set_network <network id> <variable> <value> = set network variables (shows
  get_network <network id> <variable> = get network variables
  list_creds = list configured credentials
  add_cred = add a credential
  remove_cred <cred id> = remove a credential
  set_cred <cred id> <variable> <value> = set credential variables
  save_config = save the current configuration
  disconnect = disconnect and wait for reassociate/reconnect command before
    connecting
  reconnect = like reassociate, but only takes effect if already disconnected
  scan = request new BSS scan
  scan_results = get latest scan results
  bss <<idx> | <bssid>> = get detailed scan result info
  get_capability <eap/pairwise/group/key_mgmt/proto/auth_alg/channels/freq/modes> = get capabilies
  reconfigure = force wpa_supplicant to re-read its configuration file
  terminate = terminate wpa_supplicant
  interface_add <ifname> <confname> <driver> <ctrl_interface> <driver_param>
    <bridge_name> = adds new interface, all parameters but <ifname>
    are optional
  interface_remove <ifname> = removes the interface
  interface_list = list available interfaces
  ap_scan <value> = set ap_scan parameter
  scan_interval <value> = set scan_interval parameter (in seconds)
  bss_expire_age <value> = set BSS expiration age parameter
  bss_expire_count <value> = set BSS expiration scan count parameter
  bss_flush <value> = set BSS flush age (0 by default)
  stkstart <addr> = request STK negotiation with <addr>
  ft_ds <addr> = request over-the-DS FT with <addr>
  wps_pbc [BSSID] = start Wi-Fi Protected Setup: Push Button Configuration
  wps_pin <BSSID> [PIN] = start WPS PIN method (returns PIN, if not hardcoded)
  wps_check_pin <PIN> = verify PIN checksum
  wps_cancel Cancels the pending WPS operation
  wps_nfc [BSSID] = start Wi-Fi Protected Setup: NFC
  wps_nfc_config_token <WPS|NDEF> = build configuration token
  wps_nfc_token <WPS|NDEF> = create password token
  wps_nfc_tag_read <hexdump of payload> = report read NFC tag with WPS data
  nfc_get_handover_req <NDEF> <WPS> = create NFC handover request
  nfc_get_handover_sel <NDEF> <WPS> = create NFC handover select
  nfc_rx_handover_req <hexdump of payload> = report received NFC handover request
  nfc_rx_handover_sel <hexdump of payload> = report received NFC handover select
  nfc_report_handover <role> <type> <hexdump of req> <hexdump of sel> = report completed NFC handover
  wps_reg <BSSID> <AP PIN> = start WPS Registrar to configure an AP
  wps_ap_pin [params..] = enable/disable AP PIN
  wps_er_start [IP address] = start Wi-Fi Protected Setup External Registrar
  wps_er_stop = stop Wi-Fi Protected Setup External Registrar
  wps_er_pin <UUID> <PIN> = add an Enrollee PIN to External Registrar
  wps_er_pbc <UUID> = accept an Enrollee PBC using External Registrar
  wps_er_learn <UUID> <PIN> = learn AP configuration
  wps_er_set_config <UUID> <network id> = set AP configuration for enrolling
  wps_er_config <UUID> <PIN> <SSID> <auth> <encr> <key> = configure AP
  wps_er_nfc_config_token <WPS/NDEF> <UUID> = build NFC configuration token
  ibss_rsn <addr> = request RSN authentication with <addr> in IBSS
  sta <addr> = get information about an associated station (AP)
  all_sta = get information about all associated stati** (AP)
  deauthenticate <addr> = deauthenticate a station
  disassociate <addr> = disassociate a station
  suspend = notification of suspend/hibernate
  resume = notification of resume/thaw
  drop_sa = drop SA without deauth/disassoc (test command)
  roam <addr> = roam to the specified BSS
  p2p_find [timeout] [type=*] = find P2P Devices for up-to timeout seconds
  p2p_stop_find = stop P2P Devices search
  p2p_connect <addr> <"pbc"|PIN> [ht40] = connect to a P2P Device
  p2p_listen [timeout] = listen for P2P Devices for up-to timeout seconds
  p2p_group_remove <ifname> = remove P2P group interface (terminate group if GO)
  p2p_group_add [ht40] = add a new P2P group (local end as GO)
  p2p_prov_disc <addr> <method> = request provisioning discovery
  p2p_get_passphrase = get the passphrase for a group (GO only)
  p2p_serv_disc_req <addr> <TLVs> = schedule service discovery request
  p2p_serv_disc_cancel_req <id> = cancel pending service discovery request
  p2p_serv_disc_resp <freq> <addr> <dialog token> <TLVs> = service discovery resp**e
  p2p_service_update = indicate change in local services
  p2p_serv_disc_external <external> = set external processing of service discovery
  p2p_service_flush = remove all stored service entries
  p2p_service_add <bonjour|upnp> <query|version> <resp**e|service> = add a local service
  p2p_service_del <bonjour|upnp> <query|version> [|service] = remove a local service
  p2p_reject <addr> = reject connection attempts from a specific peer
  p2p_invite <cmd> [peer=addr] = invite peer
  p2p_peers [discovered] = list known (optionally, only fully discovered) P2P peers
  p2p_peer <address> = show information about known P2P peer
  p2p_set <field> <value> = set a P2P parameter
  p2p_flush = flush P2P state
  p2p_cancel = cancel P2P group formation
  p2p_unauthorize <address> = unauthorize a peer
  p2p_presence_req [<duration> <interval>] [<duration> <interval>] = request GO presence
  p2p_ext_listen [<period> <interval>] = set extended listen timing
  p2p_remove_client <address|iface=address> = remove a peer from all groups
  wfd_subelem_set <subelem> [contents] = set Wi-Fi Display subelement
  wfd_subelem_get <subelem> = get Wi-Fi Display subelement
  sta_autoconnect <0/1> = disable/enable automatic reconnection
  tdls_discover <addr> = request TDLS discovery with <addr>
  tdls_setup <addr> = request TDLS setup with <addr>
  tdls_teardown <addr> = tear down TDLS with <addr>
  signal_poll = get signal parameters
  pktcnt_poll = get TX/RX packet counters
  reauthenticate = trigger IEEE 802.1X/EAPOL reauthentication
  raw <params..> = Sent unprocessed command
  flush = flush wpa_supplicant state
  driver <command> = driver private commands
在wpa_cli 模式下输入:
driver macaddr   则查看wifi mac地址
收藏1
