AFD高标清幅型变换软件处理
作者:halleyhuang | 时间:2016-9-29 18:02:53 | 阅读:6552| 只看该作者
       对于高标清同播的播出系统来说,如何正确完成标清与高清信号的上下变换,并保持画面内容的完整和美观,是系统设计中需要着重考虑的关键问题。
全流程应用AFD技术,可以保证高标清变换中幅型变化的正确性。常见的高标清上下变换有1000,1001,1010,1100等。软件根据比例在tvvideo_SetAspectRatio调用如下函数:
#if ENABLE_AFD
static MS_ASPECT_RATIO _CalAspectRatioWindow(MS_ASPECT_RATIO eAS,MS_U8 u8AFD,
                                                              MS_COMPONENT_OUTPUT_TYPE eCompType,
                                                              MS_U16 u16PicWidth, MS_U16 u16PicHeight,
                                                              MS_WINDOW_TYPE *pSrcWinInfo,MS_WINDOW_TYPE *pDestWinInfo)
    MS_S16 s16Offset = 0;
    MS_BOOL bCalSize = FALSE;
    MVD_ASPECT_RATIO_CODE enAspectRatio;
    GetDispAspectRatio(&enAspectRatio);
    switch(eAS)
        case MS_ASPECT_RATIO_169_PB:
        case MS_ASPECT_RATIO_169:
           if(0x09 == u8AFD)
               s16Offset = u16PicWidth*9 - u16PicHeight*14;
               if(s16Offset > 0) // 16:9
                    //source (W-xoffset*2)/H = 4/3
                    s16Offset = (3*u16PicWidth - 4*u16PicHeight);
                    if(s16Offset < 0)
                         s16Offset = - s16Offset;
                    s16Offset = s16Offset/6;
                    pSrcWinInfo->x= (s16Offset>>3)<<3;
                    pSrcWinInfo->y = 0;
                    pSrcWinInfo->width= u16PicWidth - 2*pSrcWinInfo->x;
                    pSrcWinInfo->height= u16PicHeight;
               else // 4:3
                    //source XOOffset= WO/8 ==>xoffet = W/8
                    if (enAspectRatio != MVD_ASP_4TO3)
                        s16Offset = u16PicWidth /8;
                        if(s16Offset < 0)
                        pSrcWinInfo->y = 0;
               //dest (W-xoffset*2)/H = 4/3
               s16Offset = (_setting[eCompType].u16Width - 4*_setting[eCompType].u16Height/3);
               if(s16Offset < 0)
               pDestWinInfo->x= ((s16Offset/2)>>3)<<3;
               pDestWinInfo->y = 0;
               pDestWinInfo->width= _setting[eCompType].u16Width - pDestWinInfo->x*2;
               pDestWinInfo->height= _setting[eCompType].u16Height;
               bCalSize = TRUE;
           else if(0x0B == u8AFD)
                    //source (W-xoffset*2)/H = 14/9
                    s16Offset = (9*u16PicWidth - 14*u16PicHeight);
                    if(s16Offset < 0)
                    s16Offset = s16Offset/18;
                    pSrcWinInfo->y = 0;
               else // 4:3
                    //source XOOffset= WO/9 ==>xoffet = W/16
                        s16Offset = u16PicWidth/16;
                        if(s16Offset < 0)
                        pSrcWinInfo->y = 0;
               //dest  (W-xoffset*2)/H = 14/9
               s16Offset = (9*_setting[eCompType].u16Width - 14*_setting[eCompType].u16Height);
               if(s16Offset < 0)
               s16Offset = s16Offset / 18;
               pDestWinInfo->x= (s16Offset>>3)<<3;
               pDestWinInfo->width= _setting[eCompType].u16Width - 2*pDestWinInfo->x;
               bCalSize = TRUE;
           if(eAS == MS_ASPECT_RATIO_169)
               pDestWinInfo->x= 0;
               pDestWinInfo->width= _setting[eCompType].u16Width;
           else if(bCalSize)
               eAS = MS_ASPECT_RATIO_169;
           HB_printf("###AFD ====MS_ASPECT_RATIO_169_PB!\n");
           break;
        case MS_ASPECT_RATIO_169_PS:
           HB_printf("###AFD ====MS_ASPECT_RATIO_169_PS!\n");
           break;
        case MS_ASPECT_RATIO_43_LB:
        case MS_ASPECT_RATIO_43:
           if(0x09 == u8AFD || 0x0F == u8AFD)
                   s16Offset = (u16PicWidth - 4*u16PicHeight/3);
                   if(s16Offset < 0)
                   pSrcWinInfo->x= ((s16Offset/2)>>3)<<3;
                   pSrcWinInfo->y = 0;
               else
                        if(s16Offset < 0)
                        pSrcWinInfo->y = 0;
               bCalSize = TRUE;
           else if(0x0B == u8AFD || 0x0E == u8AFD)
                   s16Offset = (u16PicWidth - 14*u16PicHeight/9);
                   if(s16Offset < 0)
                   pSrcWinInfo->y = 0;
               else // 4:3
                        if(s16Offset < 0)
                        pSrcWinInfo->y = 0;
               //Dest W/(H-2*yoffset)*(4H/3W)=14/9 -->yoffset = 6H/84
               pDestWinInfo->x= 0;
               pDestWinInfo->y = (( _setting[eCompType].u16Height *6/84)<<3)>>3;
               pDestWinInfo->height= _setting[eCompType].u16Height - pDestWinInfo->y*2;
               bCalSize = TRUE;
           if(eAS == MS_ASPECT_RATIO_43)
               pDestWinInfo->x= 0;
           else if(bCalSize)
               eAS = MS_ASPECT_RATIO_43;
           HB_printf("###AFD =====MS_ASPECT_RATIO_43_LB!=====\n");
           break;
        case MS_ASPECT_RATIO_43_PS:
           HB_printf("###AFD =====MS_ASPECT_RATIO_43_PS!=====\n");
           break;
        case MS_ASPECT_RATIO_IGNORE:
            HB_printf("###AFD =====EN_ASPECT_RATIO_IGNORE=====\n");
            break;
        default:
            break;
    return eAS;
#endif
bean.yang 发表于:2016-10-18 11:33:16
专业
