HowTo设置app不被系统kill掉
作者:linker | 时间:2016-9-29 10:59:16 | 阅读:5526| 只看该作者
有一种方法可以设置app永远不会被kill,AndroidManifest.xml 中添加:
android:persistent="true"
适用于放在/system/app下的app
设置后app提升为系统核心级别,任何情况下不会被kill掉, settings-<applicati**里面也会屏蔽掉stop操作,
设置前 Proc #19: adj=svc  /B 4067b028 255:com.xxx.xxx/10001 (started-services)
# cat /proc/255/oom_adj
4
设置后 PERS #19: adj=core /F 406291f0 155:com.xxx.xxx/10001 (fixed)
# cat /proc/155/oom_adj
-12
lowmemorykiller的操作规则比如为
write /sys/module/lowmemorykiller/parameters/adj 0,1,2,4,7,15
write /sys/module/lowmemorykiller/parameters/minfree 2048,3072,4096,6144,7168,8192
可以看到,设置persistent后, oom_adj=-12,永远没有机会被lowmemorykiller处理
android:persistent
Whether or not the application should remain running at all times — "true" if it should, and "false" if not. The default value is "false". Applicati** should not normally set this flag; persistence mode is intended only for certain system applicati**
代码
  1. ActivityManagerService.java
  2. final ProcessRecord addAppLocked(ApplicationInfo info) {
  3.         ProcessRecord app = getProcessRecordLocked(info.processName, info.uid);
  4. if (app == null) {
  5.             app = newProcessRecordLocked(null, info, null);
  6.             mProcessNames.put(info.processName, info.uid, app);
  7.             updateLruProcessLocked(app, true, true);
  8.         }
  9. if ((info.flags&(ApplicationInfo.FLAG_SYSTEM|ApplicationInfo.FLAG_PERSISTENT))
  10.                 == (ApplicationInfo.FLAG_SYSTEM|ApplicationInfo.FLAG_PERSISTENT)) {
  11.             app.persistent = true;
  12.             app.maxAdj = CORE_SERVER_ADJ;
  13.         }
  14. if (app.thread == null && mPersistentStartingProcesses.indexOf(app) < span>0) {
  15.             mPersistentStartingProcesses.add(app);
  16.             startProcessLocked(app, "added application", app.processName);
  17.         }
  18. return app;
  19.     }
复制代码
可以看到同时符合FLAG_SYSTEM(/system/app目录)及FLAG_PERSISTENT(android:persistent="true")
的app,设置app.maxAdj = CORE_SERVER_ADJ(-12),而adj=-12不会被lowmemorykiller处理0
点赞1
大神点评4
creass 发表于:2016-9-29 11:10:24
好文章要顶起来
hahaahhahaha!!123
creass 发表于:2016-9-29 11:13:12
好文章要顶起来
hahaahhahaha!!123
地板#
Mike 发表于:2016-9-30 12:06:19
学习学习
5#
creass 发表于:2016-9-30 14:29:19
好东西要顶起来,大家说对不对吗?
hahaahhahaha!!123
