SourceInsight中解决输入中文乱码问题
作者:sean | 时间:2016-9-28 20:12:51 | 阅读:5271| 只看该作者
sourceInsiht中如下操作
project------>open project--->Base------->打开Utils.em文件,在文件的最后面加上下面的内容。加完之后关闭SourceInsight重新打开即可生效。
1、BackSpace后退键
macro SuperBackspace()
    hwnd = GetCurrentWnd();
    hbuf = GetCurrentBuf();
    if (hbuf == 0)
        stop; // empty buffer
    // get current cursor postion
    ipos = GetWndSelIchFirst(hwnd);
    // get current line number
    ln = GetBufLnCur(hbuf);
    if ((GetBufSelText(hbuf) != "") || (GetWndSelLnFirst(hwnd) != GetWndSelLnLast(hwnd))) {
        // sth. was selected, del selection
        SetBufSelText(hbuf, " "); // stupid & buggy sourceinsight
        // del the " "
        SuperBackspace(1);
        stop;
    // copy current line
    text = GetBufLine(hbuf, ln);
    // get string length
    len = strlen(text);
    // if the cursor is at the start of line, combine with prev line
    if (ipos == 0 || len == 0) {
        if (ln <= 0)
            stop; // top of file
        ln = ln - 1; // do not use "ln--" for compatibility with older versi**
        prevline = GetBufLine(hbuf, ln);
        prevlen = strlen(prevline);
        // combine two lines
        text = cat(prevline, text);
        // del two lines
        DelBufLine(hbuf, ln);
        // insert the combined one
        InsBufLine(hbuf, ln, text);
        // set the cursor position
        SetBufIns(hbuf, ln, prevlen);
        stop;
    num = 1; // del one char
    if (ipos >= 1) {
        // process Chinese character
        i = ipos;
        count = 0;
        while (AsciiFromChar(text[i - 1]) >= 160) {
            i = i - 1;
            count = count + 1;
            if (i == 0)
                break;
        if (count > 0) {
            // I think it might be a two-byte character
            num = 2;
            // This idiot does not support mod and bitwise operators
            if ((count / 2 * 2 != count) && (ipos < len))
                ipos = ipos + 1; // adjust cursor position
    // keeping safe
    if (ipos - num < 0)
        num = ipos;
    // del char(s)
    text = cat(strmid(text, 0, ipos - num), strmid(text, ipos, len));
    SetBufIns(hbuf, ln, ipos - num);
    stop;
2、删除键——SuperDelete.em
macro SuperDelete()
    if (hbuf == 0)
        // del the " "
        SuperDelete(1);
        stop;
    len = strlen(text);
    if (ipos == len || len == 0) {
totalLn = GetBufLineCount (hbuf);
lastText = GetBufLine(hBuf, totalLn-1);
lastLen = strlen(lastText);
        if (ipos == lastLen)// end of file
   stop;
        ln = ln + 1; // do not use "ln--" for compatibility with older versi**
        nextline = GetBufLine(hbuf, ln);
        nextlen = strlen(nextline);
        text = cat(text, nextline);
        // del two lines
        DelBufLine(hbuf, ln-1);
        InsBufLine(hbuf, ln-1, text);
        SetBufIns(hbuf, ln-1, len);
        stop;
    if (ipos > 0) {
        i = ipos;
        count = 0;
      while (AsciiFromChar(text[i-1]) >= 160) {
            i = i - 1;
            count = count + 1;
            if (i == 0)
                break;
        if (count > 0) {
            num = 2;
            if (((count / 2 * 2 != count) || count == 0) && (ipos < len-1))
// keeping safe
if (ipos - num < 0)
            num = ipos;
    else {
i = ipos;
count = 0;
while(AsciiFromChar(text) >= 160) {
     i = i + 1;
     count = count + 1;
     if(i == len-1)
   break;
if(count > 0) {
     num = 2;
    text = cat(strmid(text, 0, ipos), strmid(text, ipos+num, len));
    SetBufIns(hbuf, ln, ipos);
    stop;
3、左移键——SuperCursorLeft.em
macro IsComplexCharacter()
if (hbuf == 0)
   return 0;
//当前位置
//当前行数
//得到当前行
//得到当前行长度
len = strlen(text);
//从头计算汉字字符的个数
if(pos > 0)
   i=pos;
   count=0;
   while(AsciiFromChar(text[i-1]) >= 160)
    i = i - 1;
    count = count+1;
    if(i == 0)
     break;
   if((count/2)*2==count|| count==0)
    return 0;
   else
    return 1;
return 0;
macro moveleft()
if (hbuf == 0)
if(GetBufSelText(hbuf) != "" || (ipos == 0 && ln == 0)) // 第0行或者是选中文字,则不移动
   stop;
if(ipos == 0)
   preLine = GetBufLine(hbuf, ln-1);
   SetBufIns(hBuf, ln-1, strlen(preLine)-1);
else
   SetBufIns(hBuf, ln, ipos-1);
macro SuperCursorLeft()
moveleft();
if(IsComplexCharacter())
   moveleft();
4、右移键——SuperCursorRight.em
macro moveRight()
if (hbuf == 0)
totalLn = GetBufLineCount(hbuf);
if(GetBufSelText(hbuf) != "") //选中文字
   ipos = GetWndSelIchLim(hwnd);
   ln = GetWndSelLnLast(hwnd);
   stop;
if(ipos == strlen(text)-1 && ln == totalLn-1) // 末行
   stop;
if(ipos == strlen(text))
   SetBufIns(hBuf, ln+1, 0);
else
   SetBufIns(hBuf, ln, ipos+1);
macro SuperCursorRight()
moveRight();
if(IsComplexCharacter()) // defined in SuperCursorLeft.em
   moveRight();
5、shift+右移键——ShiftCursorRight.em
macro IsShiftRightComplexCharacter()
if (hbuf == 0)
   return 0;
selRec = GetWndSel(hwnd);
pos = selRec.ichLim;
ln = selRec.lnLast;
len = strlen(text);
if(len == 0 || len < pos)
return 1;
//Msg("@len@;@pos@;");
if(pos > 0)
   i=pos;
   count=0;
    i = i - 1;
    count = count+1;
    if(i == 0)
     break;
    return 0;
   else
    return 1;
return 0;
macro shiftMoveRight()
if (hbuf == 0)
        stop;
curLen = GetBufLineLength(hbuf, selRec.lnLast);
if(selRec.ichLim == curLen+1 || curLen == 0)
   if(selRec.lnLast == totalLn -1)
    stop;
   selRec.lnLast = selRec.lnLast + 1;
   selRec.ichLim = 1;
   SetWndSel(hwnd, selRec);
   if(IsShiftRightComplexCharacter())
    shiftMoveRight();
   stop;
selRec.ichLim = selRec.ichLim+1;
macro SuperShiftCursorRight()
   SuperCursorRight();
shiftMoveRight();
   shiftMoveRight();
6、shift+左移键——ShiftCursorLeft.em
macro IsShiftLeftComplexCharacter()
if (hbuf == 0)
   return 0;
pos = selRec.ichFirst;
ln = selRec.lnFirst;
len = strlen(text);
   return 1;
if(pos > 0)
   i=pos;
   count=0;
    i = i - 1;
    count = count+1;
    if(i == 0)
     break;
    return 0;
   else
    return 1;
return 0;
macro shiftMoveLeft()
if (hbuf == 0)
        stop;
//curLen = GetBufLineLength(hbuf, selRec.lnFirst);
//Msg("@curLen@;@selRec@");
if(selRec.ichFirst == 0)
   if(selRec.lnFirst == 0)
    stop;
   selRec.lnFirst = selRec.lnFirst - 1;
   selRec.ichFirst = GetBufLineLength(hbuf, selRec.lnFirst)-1;
   if(IsShiftLeftComplexCharacter())
    shiftMoveLeft();
   stop;
selRec.ichFirst = selRec.ichFirst-1;
macro SuperShiftCursorLeft()
   SuperCursorLeft();
shiftMoveLeft();
   shiftMoveLeft();
/*---END---*/
该会员没有填写今日想 ...
steven 发表于:2016-9-29 10:14:14
最好的方法就是不用中文
