Android系统镜像文件的打包|过程分析(2)
作者:liuwei | 时间:2016-9-28 13:13:29 | 阅读:4552| 只看该作者
注意,ALL_DEFAULT_INSTALLED_MODULES描述的文件除了在build/core/main.mk文件中定义的模块文件之外,还包含以下这些文件:
        1. 通过PRODUCT_COPY_FILES定义的要拷贝到目标设备上去的文件
[plain] view plain copy
  • unique_product_copy_files_pairs :=
  • $(foreach cf,$(PRODUCT_COPY_FILES), \
  •     $(if $(filter $(unique_product_copy_files_pairs),$(cf)),,\
  •         $(eval unique_product_copy_files_pairs += $(cf))))
  • unique_product_copy_files_destinati** :=
  • $(foreach cf,$(unique_product_copy_files_pairs), \
  •     $(eval _src := $(call word-colon,1,$(cf))) \
  •     $(eval _dest := $(call word-colon,2,$(cf))) \
  •     $(call check-product-copy-files,$(cf)) \
  •     $(if $(filter $(unique_product_copy_files_destinati**),$(_dest)), \
  •         $(info PRODUCT_COPY_FILES $(cf) ignored.), \
  •         $(eval _fulldest := $(call append-path,$(PRODUCT_OUT),$(_dest))) \
  •         $(if $(filter %.xml,$(_dest)),\
  •             $(eval $(call copy-xml-file-checked,$(_src),$(_fulldest))),\
  •             $(eval $(call copy-one-file,$(_src),$(_fulldest)))) \
  •         <span style="color:#FF0000;"><strong>$(eval ALL_DEFAULT_INSTALLED_MODULES += $(_fulldest)) \</strong></span>
  •         $(eval unique_product_copy_files_destinati** += $(_dest))))
        2.  由ADDITIONAL_DEFAULT_PROPERTIES定义的属性所组成的default.prop文件
  • INSTALLED_DEFAULT_PROP_TARGET := $(TARGET_ROOT_OUT)/default.prop
  • <span style="color:#FF0000;"><strong>ALL_DEFAULT_INSTALLED_MODULES += $(INSTALLED_DEFAULT_PROP_TARGET)</strong></span>
  • ADDITIONAL_DEFAULT_PROPERTIES := \
  •     $(call collapse-pairs, $(ADDITIONAL_DEFAULT_PROPERTIES))
  • ADDITIONAL_DEFAULT_PROPERTIES += \
  •     $(call collapse-pairs, $(PRODUCT_DEFAULT_PROPERTY_OVERRIDES))
  • ADDITIONAL_DEFAULT_PROPERTIES := $(call uniq-pairs-by-first-component, \
  •     $(ADDITIONAL_DEFAULT_PROPERTIES),=)
  • $(INSTALLED_DEFAULT_PROP_TARGET):
  •     @echo Target buildinfo: $@
  •     @mkdir -p $(dir $@)
  •     $(hide) echo "#" > $@; \
  •             echo "# ADDITIONAL_DEFAULT_PROPERTIES" >> $@; \
  •             echo "#" >> $@;
  •     $(hide) $(foreach line,$(ADDITIONAL_DEFAULT_PROPERTIES), \
  •         echo "$(line)" >> $@;)
  •     build/tools/post_process_props.py $@
         3. 由ADDITIONAL_BUILD_PROPERTIES等定义的属性所组成的build.prop文件
  • INSTALLED_BUILD_PROP_TARGET := $(TARGET_OUT)/build.prop
  • <span style="color:#FF0000;"><strong>ALL_DEFAULT_INSTALLED_MODULES += $(INSTALLED_BUILD_PROP_TARGET)</strong></span>
  • ADDITIONAL_BUILD_PROPERTIES := \
  •     $(call collapse-pairs, $(ADDITIONAL_BUILD_PROPERTIES))
  • ADDITIONAL_BUILD_PROPERTIES := $(call uniq-pairs-by-first-component, \
  •     $(ADDITIONAL_BUILD_PROPERTIES),=)
  • BUILDINFO_SH := build/tools/buildinfo.sh
  • $(INSTALLED_BUILD_PROP_TARGET): $(BUILDINFO_SH) $(INTERNAL_BUILD_ID_MAKEFILE) $(BUILD_SYSTEM)/version_defaults.mk $(wildcard $(TARGET_DEVICE_DIR)/system.prop)
  •     $(hide) TARGET_BUILD_TYPE="$(TARGET_BUILD_VARIANT)" \
  •             TARGET_DEVICE="$(TARGET_DEVICE)" \
  •             PRODUCT_NAME="$(TARGET_PRODUCT)" \
  •             PRODUCT_BRAND="$(PRODUCT_BRAND)" \
  •             PRODUCT_DEFAULT_LANGUAGE="$(call default-locale-language,$(PRODUCT_LOCALES))" \
  •             PRODUCT_DEFAULT_REGION="$(call default-locale-region,$(PRODUCT_LOCALES))" \
  •             PRODUCT_DEFAULT_WIFI_CHANNELS="$(PRODUCT_DEFAULT_WIFI_CHANNELS)" \
  •             PRODUCT_MODEL="$(PRODUCT_MODEL)" \
  •             PRODUCT_MANUFACTURER="$(PRODUCT_MANUFACTURER)" \
  •             PRIVATE_BUILD_DESC="$(PRIVATE_BUILD_DESC)" \
  •             BUILD_ID="$(BUILD_ID)" \
  •             BUILD_DISPLAY_ID="$(BUILD_DISPLAY_ID)" \
  •             BUILD_NUMBER="$(BUILD_NUMBER)" \
  •             PLATFORM_VERSION="$(PLATFORM_VERSION)" \
  •             PLATFORM_SDK_VERSION="$(PLATFORM_SDK_VERSION)" \
  •             PLATFORM_VERSION_CODENAME="$(PLATFORM_VERSION_CODENAME)" \
  •             BUILD_VERSION_TAGS="$(BUILD_VERSION_TAGS)" \
  •             TARGET_BOOTLOADER_BOARD_NAME="$(TARGET_BOOTLOADER_BOARD_NAME)" \
  •             BUILD_FINGERPRINT="$(BUILD_FINGERPRINT)" \
  •             TARGET_BOARD_PLATFORM="$(TARGET_BOARD_PLATFORM)" \
  •             TARGET_CPU_ABI="$(TARGET_CPU_ABI)" \
  •             TARGET_CPU_ABI2="$(TARGET_CPU_ABI2)" \
  •             TARGET_AAPT_CHARACTERISTICS="$(TARGET_AAPT_CHARACTERISTICS)" \
  •             bash $(BUILDINFO_SH) > $@
  •     $(hide) if [ -f $(TARGET_DEVICE_DIR)/system.prop ]; then \
  •               cat $(TARGET_DEVICE_DIR)/system.prop >> $@; \
  •             fi
  •     $(if $(ADDITIONAL_BUILD_PROPERTIES), \
  •         $(hide) echo >> $@; \
  •                 echo "#" >> $@; \
  •                 echo "# ADDITIONAL_BUILD_PROPERTIES" >> $@; \
  •                 echo "#" >> $@; )
  •     $(hide) $(foreach line,$(ADDITIONAL_BUILD_PROPERTIES), \
  •     $(hide) build/tools/post_process_props.py $@
         4. 用来描述event类型日志格式的event-log-tags文件
  • all_event_log_tags_file := $(TARGET_OUT_COMMON_INTERMEDIATES)/all-event-log-tags.txt
  • event_log_tags_file := $(TARGET_OUT)/etc/event-log-tags
  • # Include tags from all packages that we know about
  • all_event_log_tags_src := \
  •     $(sort $(foreach m, $(ALL_MODULES), $(ALL_MODULES.$(m).EVENT_LOG_TAGS)))
  • # PDK builds will already have a full list of tags that needs to get merged
  • # in with the ones from source
  • pdk_fusion_log_tags_file := $(patsubst $(PRODUCT_OUT)/%,$(_pdk_fusion_intermediates)/%,$(filter $(event_log_tags_file),$(ALL_PDK_FUSION_FILES)))
  • $(all_event_log_tags_file): PRIVATE_SRC_FILES := $(all_event_log_tags_src) $(pdk_fusion_log_tags_file)
  •     $(hide) mkdir -p $(dir $@)
  •     $(hide) build/tools/merge-event-log-tags.py -o $@ $(PRIVATE_SRC_FILES)
  • # Include tags from all packages included in this product, plus all
  • # tags that are part of the system (ie, not in a vendor/ or device/
  • # directory).
  • event_log_tags_src := \
  •     $(sort $(foreach m,\
  •       $(PRODUCTS.$(INTERNAL_PRODUCT).PRODUCT_PACKAGES) \
  •       $(call module-names-for-tag-list,user), \
  •       $(ALL_MODULES.$(m).EVENT_LOG_TAGS)) \
  •       $(filter-out vendor/% device/% out/%,$(all_event_log_tags_src)))
  • $(event_log_tags_file): PRIVATE_SRC_FILES := $(event_log_tags_src) $(pdk_fusion_log_tags_file)
  • $(event_log_tags_file): PRIVATE_MERGED_FILE := $(all_event_log_tags_file)
  • $(event_log_tags_file): $(event_log_tags_src) $(all_event_log_tags_file) $(pdk_fusion_log_tags_file)
  •     $(hide) build/tools/merge-event-log-tags.py -o $@ -m $(PRIVATE_MERGED_FILE) $(PRIVATE_SRC_FILES)
  • event-log-tags: $(event_log_tags_file)
  • <strong><span style="color:#FF0000;">ALL_DEFAULT_INSTALLED_MODULES += $(event_log_tags_file)</span></strong>
        关于Android系统的event日志,可以参考Android日志系统驱动程序Logger源代码分析、Android应用程序框架层和系统运行库层日志系统源代码分析和Android日志系统Logcat源代码简要分析这个系列的文章。
        5. 由于使用了BSD、GPL和Apache许可的模块而必须在发布时附带的Notice文件
  • target_notice_file_txt := $(TARGET_OUT_INTERMEDIATES)/NOTICE.txt
  • target_notice_file_html := $(TARGET_OUT_INTERMEDIATES)/NOTICE.html
  • target_notice_file_html_gz := $(TARGET_OUT_INTERMEDIATES)/NOTICE.html.gz
  • tools_notice_file_txt := $(HOST_OUT_INTERMEDIATES)/NOTICE.txt
  • tools_notice_file_html := $(HOST_OUT_INTERMEDIATES)/NOTICE.html
  • kernel_notice_file := $(TARGET_OUT_NOTICE_FILES)/src/kernel.txt
  • pdk_fusion_notice_files := $(filter $(TARGET_OUT_NOTICE_FILES)/%, $(ALL_PDK_FUSION_FILES))
  • # Install the html file at /system/etc/NOTICE.html.gz.
  • # This is not ideal, but this is very late in the game, after a lot of
  • # the module processing has already been done -- in fact, we used the
  • # fact that all that has been done to get the list of modules that we
  • # need notice files for.
  • $(target_notice_file_html_gz): $(target_notice_file_html) | $(MINIGZIP)
  •     $(hide) $(MINIGZIP) -9 < $< > $@
  • installed_notice_html_gz := $(TARGET_OUT)/etc/NOTICE.html.gz
  • $(installed_notice_html_gz): $(target_notice_file_html_gz) | $(ACP)
  •     $(copy-file-to-target)
  • # if we've been run my mm, mmm, etc, don't reinstall this every time
  • ifeq ($(ONE_SHOT_MAKEFILE),)
  • <span style="color:#FF0000;"><strong>ALL_DEFAULT_INSTALLED_MODULES += $(installed_notice_html_gz)</strong></span>
  • endif
        6. 用来验证OTA更新的ZS文件
  • <span style="color:#FF0000;"><strong>ALL_DEFAULT_INSTALLED_MODULES += $(TARGET_OUT_ETC)/security/otacerts.zip</strong></span>
  • $(TARGET_OUT_ETC)/security/otacerts.zip: KEY_CERT_PAIR := $(DEFAULT_KEY_CERT_PAIR)
  • $(TARGET_OUT_ETC)/security/otacerts.zip: $(addsuffix .x509.pem,$(DEFAULT_KEY_CERT_PAIR))
  •     $(hide) rm -f $@
  •     $(hide) zip -qj $@ $<
  • .PHONY: otacerts
  • otacerts: $(TARGET_OUT_ETC)/security/otacerts.zip
liuwei 发表于:2016-9-28 14:10:19
